circuit breaker resetting
Old Oct 24, 2011 | 08:17 PM
ryndraeger's Avatar
ryndraeger is on a distinguished road
Default circuit breaker resetting
Hi guys I have a 99 jimmy 4.3 four wheel drive, and there is a 25 amp circuit breaker clicking on and off under the dash everything in the vehicle works except for the power seats I have removed the drivers seat and checked the seat wiring all looks good. I have pulled up the carpet and checked the harness, can't see anything obvious there either. After the battery has been unhooked for a while and then rehooked the seats both work fine for a little while then they stop working. The battery will drain conmpletly after two days if the vehicle is not ran. I know this is all pointing to a short to ground somewhere I need any ideas of where to continue looking. thanks Ryan
Old Oct 24, 2011 | 08:31 PM
coolasice's Avatar
coolasice will become famous soon enough
try leaving your seats unplugged... could be a bad switch on one of your seats, if it doesn't trip any after they've been unplugged for some time, then it's def one of the seats.
Old Oct 24, 2011 | 08:59 PM
ryndraeger's Avatar
The drivers seat is out of the vehicle I will unplug the passenger seat. Thanks for the reply.
Old Oct 25, 2011 | 06:38 PM
ryndraeger's Avatar
I found a broken wire touching the metal seat track under the passenger seat. It was one of the orange ones coming from the main harness.
Old Oct 25, 2011 | 09:09 PM
coolasice's Avatar
voila... there's your problem..
Flyfishen
15
Nov 15, 2012 06:14 PM
maling
Dec 11, 2010 10:27 AM
global_dev
Nov 24, 2009 06:42 AM
bragdog
Sep 8, 2008 03:51 PM
rirby
Sep 16, 2007 11:20 AM
