Connecting Lights to Battery
change the battery cable bolt to one of these side post extenders
Tsunami/GM battery side post adapter (BT306) | Battery Terminal End and Adapter | AutoZone.com
Hey guys I've got a new problem now my lights are the kc daylighter 634s 130w driving lights with relay. While I was driving the ground to my switch came loose and now the lights won't work and the green light on the switch doesn't light up. Did I blow the fuses or what's going on?
I drilled a hole in the metal arm of the e brake for my ground so I don't think it's anything on that end but where the ground came up to the switch is where it came loose. I've held the wire back up to the switch to see if it will work but nothing.
