Dash and headlights flicker while accelerating.. Engine dies ocassionally
Old May 10, 2011 | 01:41 PM
2002TwoDoor's Avatar
2002TwoDoor is on a distinguished road
This sounds like the issue that I am fighting. I have narrowed it down to the battery connection. The factory side mount terminals have 3 tabs on them that dig into the battery and after normal wear it causes a gap between the terminal and the battery. This seems to restrict both charging of the battery and the starting of the Blazer. I can actually see where it is arcing. I have done my best to file the metal smooth again but it seems to be a losing battle. Does anyone have any other suggestions? I am considering just going to a standard post mount for the battery but would prefer not to.
Old May 11, 2011 | 06:05 PM
Rottidog's Avatar
This is how I have mine. It works great AND I have solid connections for booster cables if need be. If you use 2 nuts then you can leave the nut against the side terminal tight & back off the 2nd nut to add accesories/spade connections.
Attached Thumbnails Dash and headlights flicker while accelerating.. Engine dies ocassionally-dscn0445.jpg
Old May 14, 2011 | 05:14 PM
mrkevinmjr's Avatar
mrkevinmjr is on a distinguished road
i will try this and pick up new battery cable... replace the old crap.
poertsch
Mar 4, 2014 08:06 PM
kgpace
Jan 2, 2011 03:42 PM
Nizm0
Apr 30, 2010 09:32 PM
marine
Jan 28, 2010 07:05 PM
recruiter
Jan 5, 2007 02:58 PM
