Dash Lights Out
Old Jan 23, 2013 | 01:51 AM
808Hawaiian's Avatar
808Hawaiian is on a distinguished road
Always start with the simple, most cheap route. Then work your way to the more complicated item such as the ignition switch.
Dont just want to throw parts in without diagnosing.
What happens when you wiggle your keys in the ignition?
Sorry for the late reply but what am i looking for when i wiggle my keys? Sorry if that sounds dumb but i dont know what to look for i tried turning the key off and on but still nothing.
Old Jan 23, 2013 | 02:38 AM
xgiovannix12's Avatar
Originally Posted by 808Hawaiian
Sup guys i tried the ground, cleaned it and still nothing. Any other advice? After alot of research im thinking that it just might be the ignition thanks for all the help
follow the link I posted.
Old Jan 23, 2013 | 04:06 AM
Thanks for that link man. i did follow it. Thats another reason why i think its the ignition switch.
Old Jan 23, 2013 | 05:49 AM
4X4GS10B's Avatar
4X4GS10B is on a distinguished road
I agree with chesty puller I have seen way too many ignition switches go bad in these dang things I've also seen all different kind of symptoms it went along with it, I'm a firm believer in big k.i.s.s philosophy. I have seen symptoms go from hard starts to no dash lights 2 transmission codes.
Old Jan 23, 2013 | 04:50 PM
chestypuller's Avatar
Banned
chestypuller can only hope to improve
ignition switch i say it again. get one on amazon.com they have oem gm ones for 60$
Old Jan 31, 2013 | 01:24 AM
Sorry for the late reply guys but thanks for all the help...i went out and got an ignition switch and will be putting it in this weekend...im getting kinda worried about doing the passlock i did some research found alot of threads with this procedure just wanted to know if anybody had any advice on this before i get wrenching thanks
Old Jan 31, 2013 | 01:28 AM
Disconnect your battery.
Old Jan 31, 2013 | 01:30 PM
Thanks so i wont have to worry about the passlock procedure if i disconnect the battery before i put the switch in?
P.s. i was gonna disconnect it anyways because of the airbag.
Old Feb 3, 2013 | 01:07 AM
Sup guys got some bad news so i changed the ignition switch and still nothing happend everything is still the same. I checked all connections, fuses, battery terminals, grounds everything is good. I dont know what else to do really frustrated with this problem any help is appreciated thanks.
Old Feb 3, 2013 | 04:00 AM
Banned
aint that a bitch.
