Dash replacement, electrical issues now
Old Nov 14, 2012 | 06:07 PM
nunya's Avatar
nunya is on a distinguished road
Default Dash replacement, electrical issues now
Now this is our little shop runner not my blazer but its similar enough I figured I'd ask so as to maby get an idea of something I possibly missed.
The info: 1997 2wd s10 cab&1/2 4.3 auto.
The original issue: it needed a heater core and while the dash was out (it was in horrible shape) it got replaced.
The problem: after changeover (donor dash was from a 97 4x4 blazer) the brake warning light is dimly lit, no blower motor, and the power windows don't work. I used the correct cluster that matched the truck originally (wasn't giving up my 200k mileage) but the donor dash wiring as the original had some half-fast hacking in the radio harness. Did I miss something possibly or am I pulling the dash back out (not that I mind that) and switching harnesses?
Old Nov 14, 2012 | 06:24 PM
richphotos's Avatar
Are you sure that you connected everything all the way? It seems like a pretty common problem I see on this site after someone replaces a heater core that they have some sort of electrical problem, and have to back over everything a second time.
Old Nov 14, 2012 | 06:36 PM
nunya's Avatar
Enforce bolting it down I 2nd guessed myself and slid it back forward (because I DID forget to put the antenna wire through at first) so I doubled over all plugs before the boltdown. (I look down on no suggestions feel free no matter how trivial it may sound)
Old Nov 15, 2012 | 05:52 PM
nunya's Avatar
Problem solved, I had to switch harnesses so the one from the truck was in the new dash and everything is back to normal. So useful information, don't ditch your old harness!
Old Nov 15, 2012 | 06:43 PM
richphotos's Avatar
Thanks for posting your solution. It drives me nuts when someone fixes something, and just posts "I fixed it" and that is that.
Glad you got it figured out.
Old Nov 15, 2012 | 07:19 PM
nunya's Avatar
Yea "it's fixed" ain't a helpful solution and bothers me just finding it as an answer when I hunt a problem.
kframe357
May 8, 2014 10:09 PM
JoSHN
Sep 14, 2012 04:56 PM
nepa zr2
Mar 15, 2012 03:57 PM
cjh
Nov 24, 2008 08:46 PM
auntjanet
Apr 30, 2008 08:28 PM
