Did my Blazer used to have a key fob?
Old Jan 23, 2012 | 05:47 PM
neksys's Avatar
neksys is on a distinguished road
Default Did my Blazer used to have a key fob?
I have keys for my Blazer (obviously) but I was wondering if it originally came with a key fob/transmitter.
Here are my hints:
1) 2001 4WD/4DR LS Blazer
2) There is no key hole in the tailgate
3) It has power everything (door locks, etc.)
Is there any way to tell whether this Blazer came with the fob from the factory? If so, how can I tell?
Old Jan 23, 2012 | 06:06 PM
pettyfog's Avatar
Old Jan 23, 2012 | 06:48 PM
neksys's Avatar
Originally Posted by pettyfog
Thanks for the link but I don't see anything in that thread that tells me whether my Blazer ever had remote keyless entry to begin with.
I can try to buy a key fob and try to sync it as per that thread, but that is what I am trying to avoid if the Blazer doesn't have RKE anyways!
Old Jan 24, 2012 | 07:58 AM
pettyfog's Avatar
Well. If it didnt come able to handle a key fob, then it wouldnt signal that it was in 'learn mode'. That signal will happen whether or not you actually have a fob, right?
Hold down unlock on the door.
Cycle key on, off, on, off. Doors should lock and unlock.
Where else would that be coming from, if it didnt have RKE?
So, if you get that to happen.. THEN:
Hold down unlock and lock on key fob until locks cycle again.
Gm doesnt usually put in funct that wont be used.
Old Jan 28, 2012 | 07:55 PM
neoalphaflight's Avatar
neoalphaflight is on a distinguished road
I would check the RPO codes listed on your glove box to find out for sure. I believe if it did come with it the code listed would be. AU0 : LOCK CONTROL, REMOTE ENTRY – KEYLESS ENTRY (DOMESTIC)
Old Jan 29, 2012 | 06:45 PM
wyzardd's Avatar
wyzardd is on a distinguished road
So, the key to figuring out if an 02 Blazer used to have the remote keyless doohickey thing is if there is a keyhole in the tailgate? Bummer.
changeme20
Oct 24, 2020 02:12 AM
justblazin1
Dec 19, 2018 01:41 AM
Läyskä
Mar 5, 2012 09:24 AM
acfiero
Mar 30, 2010 07:37 AM
ray bright
Mar 2, 2009 09:56 AM
