Distributor rotor issues
Old Apr 10, 2021 | 05:16 PM
lucentstone969's Avatar
lucentstone969 is on a distinguished road
Default Distributor rotor issues
Hi all. I have a 2002 blazer 4x4 4.3l
I have put 2 new ac delco distributors in because the rotor's screw keeps coming out and jamming the rotor and spinning the mounting plate on shaft. Any ideas on how to stop this?
Old Apr 10, 2021 | 06:43 PM
Put a dab of blue Loctite on the screws?
Old Apr 11, 2021 | 07:04 AM
Yes I did the blue loctite
Old Apr 11, 2021 | 07:22 AM
Walleye Hunter's Avatar
Walleye Hunter will become famous soon enough
If you have them tightened correctly, I can't understand why it would throw them. How long does it take?
Old Apr 11, 2021 | 02:31 PM
Are the screws not long enough? Have you checked if the threads of the distributors were cut correctly? This latter issue is unlikely but it's got to be something.
Old Apr 11, 2021 | 02:33 PM
Cap n rotor were orig to dist that we bought, already on it , never touched it. 1st time 136k OE then 2nd about 2 yrs, 3rd time about 2yrs. Both AC delco from big name part store. Ran great til it died. Only did plugs n wires in between.
Old Apr 13, 2021 | 02:16 AM
How do the other parts of the distributor look?
Does the rotor move up and down?
Worn gear which can cause the shaft to push up?
Internal bearing loose?
Sideways movement of the rotor/shaft?
WangDangler
41
Sep 20, 2018 11:01 PM
Steviepc7
Nov 4, 2015 04:13 PM
Krafty10
Apr 11, 2015 08:03 PM
dyeguy1212
Apr 4, 2012 09:48 AM
vatoDETH
Aug 22, 2010 04:41 PM
