do the wires exist
Old Nov 29, 2010 | 03:34 PM
myprixxx's Avatar
myprixxx is on a distinguished road
Default do the wires exist
Ok I have a 98 blazer without the stock fogs. My question is, if I stil have an extra headlight switch from my old blazer withstock fogs, if I found or purchased a set of the stock blazer fog ligths is the wiring there for it? Or could I get the wiring harness for one with fogs? The easiest way I can say it is is the wire for the stock fogs still in the harness just being unused, or is the wiring missing completely?
Old Nov 29, 2010 | 08:20 PM
Depends. Some have found them, others have not. Just have to dig in and see.
About getting them working, a quick search for "adding+fogs" returned this:
Originally Posted by Monkeyman
Depending on the year, the wiring should be there from the headlight/fog light switch to the BCM, from the BCM to the under hood fuse box and from the under hood fuse box to the fog lights (that aren't there). (Note: I may have that order wrong.) Notice I mentioned the BCM. You'll have to get the foglight program added to the BCM for the OEM switch to work. Costs somewhere around $100 and probably a trip to the dealer as they have to call GM and get a number to program in the Tech2. After that, all you should have to do is plug in the foglight bulbs (880/881) and you're good to go.
I'm adding aftermarket fog lights but I'll probably pony up the money and have the BCM programmed for factory fogs sometime, too.
Old Nov 30, 2010 | 11:49 AM
myprixxx's Avatar
exactly what i needed, thank you
Old Dec 1, 2010 | 07:12 PM
Lula Tacoma's Avatar
Lula Tacoma is on a distinguished road
Why not just run new wires off a toggle switch to your fogs? It will get you around to programing. You could also use a relay and turn them on with your headlights.
maxvamp
Oct 31, 2020 08:19 AM
Mrthelaxer
Mar 20, 2013 08:00 PM
sledneck16
Oct 15, 2008 10:26 AM
rogggg1020
Sep 24, 2008 06:53 AM
KFC_Or_Bust
Jul 29, 2008 08:23 AM
