ECM IGN fuse blows when I start my 97 blazer
Old May 25, 2021 | 06:55 PM
jennigodinez2468's Avatar
jennigodinez2468 is on a distinguished road
Default ECM IGN fuse blows when I start my 97 blazer
I have a 97 blazer wont start .when i turn key it shorts out fuse #10 Ecm ign
Old May 26, 2021 | 08:38 AM
That fuse powers your ignition coil, ignition control module, and fuel injectors. If there's a short in any of the wiring to those components, it would cause the fuse to blow. Just for kicks, try unplugging the coil and see if the fuse stops blowing. That probably isn't the problem, but it only takes a minute to check it.
Old May 27, 2021 | 03:49 PM
Mods's Avatar
in addition, if it still blows, unplug the ICM, Injector harness plug, and see if it still occurs, if so you have to go deeper into the wiring.
Old May 27, 2021 | 06:55 PM
Going down a rabbit hole....
Sorry watching Alice in wonderland 😀
Bluesmoke99
Jan 28, 2021 02:56 AM
johnnysauur
Jan 31, 2019 06:04 PM
brain7734
Oct 1, 2013 11:14 AM
Xavier
Jan 31, 2012 06:22 PM
