Electrical problems in driver's door
Old May 23, 2013 | 03:07 AM
Lbrooks's Avatar
Lbrooks is on a distinguished road
Default Electrical problems in driver's door
My 1999 Blazer has electrical problems in the driver's side door. The window will work fine sometimes and sometimes it will only go up a little, but if I wait a few minutes it'll go up a little more, and so on until it's up all the way. The radio speaker in the door is "fuzzy" also, and the door will lock with the key fob but the actual lock will not engage. A while back the door started sagging and my wife would slam the door very hard to get it shut. I replaced the bushings and now it shuts fline, but the electrical problems drive me crazy. The speaker in the rear driver's side door doesn't work at all. Could she have knocked something loose or broken something?
Old May 23, 2013 | 04:10 PM
WitchingHour's Avatar
WitchingHour is an unknown quantity at this point
Are they the OEM speakers? Is the sound system OEM? Before you go replacing the window motor, check the connection. It could be loose or corroded. Check the wire passage through the door jamb, as well - it's possible they got pinched there at some point. Finally, inspect the switch.
I'm a little doubtful it's your wife's doing. GM hasn't had the highest if success rates with their power windows, and speakers go out sometimes. I'll leave it to someone else to cover the door lock.
Old May 23, 2013 | 07:19 PM
keepitdirty's Avatar
keepitdirty is on a distinguished road
Default electric window?
Probably. Had same problem with window, and door sag, not with speakers. Replaced window motor, it is side specific. this was very tricky, required two people, vice grips, eye protection, if you have never done this, try to find some one who has. I was able to do it, but think I was lucky. The problem could be window operator control. I questioned mine when doing this repair. Seemed kind flimsy. If I remember right I was able to jump switch out some how, and motor still acted funny. If you do attempt doing this be extremely careful , I remember inside of that door, it was like a big pair of scissors. I used a rebuilt ,was a lot cheaper, but I have heard of them not being reliable.:icon _wheel:
mamawolf70
Apr 10, 2020 10:44 AM
Ryan Johnson
Aug 14, 2014 10:18 PM
JoSHN
Sep 14, 2012 04:56 PM
MikeTastic
Aug 8, 2012 04:41 PM
UMishap
Apr 24, 2011 04:03 PM
