engine wire harness interchange
Old Dec 30, 2010 | 11:56 PM
metzkerdavid's Avatar
metzkerdavid is on a distinguished road
Default engine wire harness interchange
Will a 1973 engine wire harness work on a 1978 or what years will interchange with each other thanks.
Old Dec 31, 2010 | 06:31 AM
The engine harness will be different between those two years primarily in the distributor/coil wiring. The 78 will likely have an HEI distributor which requires a +12V ignition switched source for the distributor while the points style distributor the 73 came with stock will only have +12V for cranking then it will drop to ~6V to the coil.
As far as what other years will interchange, you can typically go up/down a few years. 75 was the first year that all vehicles were HEI distributor so I'd say 75 to probably 80 should be safe.
Whats wrong with your harness?
Old Dec 31, 2010 | 12:21 PM
thanks swartlkk
The wires got caught it the steering shaft and pulled them out of the little black box that plugs into the fire wall.
Last edited by swartlkk; Dec 31, 2010 at 01:39 PM. Reason: *Combining Consecutive Posts* - Please use the edit function to add additional information in your post if another member has yet to respond.
AdsoYo
Nov 14, 2013 09:52 AM
Deborah J Pinkston
Apr 18, 2012 10:40 AM
bmxrr1990
Engine & Internal
Feb 15, 2008 06:55 AM
lemon blazer
Feb 1, 2007 06:04 PM
scottydl
Sep 16, 2006 08:53 PM
