Flasher noise!
Old Jul 16, 2011 | 06:45 PM
JohnA's Avatar
JohnA is on a distinguished road
Question Flasher noise!
I have a 96' S10 LS and since I bought it it's had a flasher noise and my blinkers wouldn't flash,a couple of weeks ago my brake lights went out and the noise stopped, I replaced the fuse and not only did the brake lights work but so did the blinkers, they went out again the other day and I tried to replace the fuse and it pops as soon as I put it in,I tried 5 different fuse's and they popped too. I've looked for the blinker flasher and cannot see it, can anyone tell me where the flasher is and how to get to it.Or if you think it might be something else I'm open to suggestions.
Old Jul 17, 2011 | 01:10 PM
This is a fairly common problem. Typing "clicking+behind+dash" into the search box should get your the pertinent results. Typically, this is caused by problem in the multifunction switch.
BTW, please do not PM for tech help. The link in my signature explains why.
Old Jul 17, 2011 | 03:06 PM
JohnA's Avatar
Ok, so I just went out and replaced the fuse again and it didn't pop, had the key off, the clicking noise was back I turned the key on and then off and the starter started going on and off and then the fuse blew, now I'm really confused, could the Multifunction switch cause this?
medway creek
Nov 5, 2009 08:49 AM
Cooligan
Nov 12, 2007 11:44 AM
apekim
Sep 15, 2007 10:46 AM
syrblitz19
Jun 10, 2006 02:27 AM
kccapt
Nov 23, 2005 01:34 AM
