Flashing headlights?
Old Apr 11, 2011 | 09:17 AM
CraigSnedeker's Avatar
Default Flashing headlights?
Is it just my blazer, or can you not flash your headlights? I've tested it before with my sister and nothing happens when I try to flash my headlights (lights turned off.)
Is something just broken?
Old Apr 11, 2011 | 09:50 AM
CNYCountryKidd's Avatar
CNYCountryKidd is on a distinguished road
If it has DRL's you should be able to.. if not, oh well. I've never seen a vehicle without DRL's have the ability to flash when they are off.
Old Apr 11, 2011 | 11:20 AM
Benedict1337's Avatar
yea mine did that before I disabled them... can you flash them when your lights are on?
Old Apr 11, 2011 | 12:31 PM
warthogdriver's Avatar
my drl is disabled and i can still flash the highs no problem.
Old Apr 11, 2011 | 02:10 PM
Rottidog's Avatar
I have DRL's & 1 1/2 pull back on the turn signal & my high beams flash. Not sure about during the day but I think they do.
Old Apr 12, 2011 | 07:58 AM
No, it just turns high beams on.
No idea what a DRL is.
Old Apr 12, 2011 | 02:19 PM
Rottidog's Avatar
DRL = Daytime Running Lights
Old Apr 12, 2011 | 03:45 PM
cbr995's Avatar
Are you talking about Flash to Pass?
GM started doing that on the newer models. Our '95 Suburban doesn't have that either.
Basically the High Beams turn on before you pull the lever all the way back to switch them on.
Old Apr 12, 2011 | 03:58 PM
when you're daytime runners are on you should be able to hit the high beam switch and the will stay on only for as long as you have the switch held back
Old Apr 13, 2011 | 08:42 AM
Alright, I'll try these today and see if it works!
247monster
Jul 11, 2012 08:41 PM
hollywoodgrad
Jan 25, 2012 01:58 PM
247monster
Jan 24, 2012 10:07 PM
blazerbenson
Mar 5, 2011 08:24 PM
erl982wd
Jun 10, 2005 04:12 PM
