Flickering Headlights
Old Feb 4, 2019 | 06:04 PM
Blazer112's Avatar
Blazer112 is on a distinguished road
Default Flickering Headlights
I have been having issues with my passenger headlight flickering on my 04 Blazer. I was installing a new battery tray when I noticed three ground connections below the tray. They were screwed into the front metal just below the tray and above the 4WD vacuum actuator. The “grounds” were extremely corroded and rusted. (One was a 10-12awg or so wire, so it was carrying a decent load). I cleaned them with a wire brush and crimped on new wire connectors. I finished by coating them with dielectric grease. No more flickering. I have no idea if these ground wires are correlated to the lights but it solved my problem as electricity can be a fickle issue. I hope it helps others. By the way, if you remove the battery tray, the bolts are secured by 2 “crimp on” square style nuts which may fall down never to be seen again in the crevices of the frame.
Old Feb 5, 2019 | 06:16 AM
cleburne red's Avatar
Those grounds are definitely for the headlights, at least on mine that's where they were.
Old Feb 5, 2019 | 02:26 PM
Blazer112's Avatar
Default Thanks
I was wondering and feel better now so thanks for letting me know.
Westy
Feb 22, 2019 01:43 PM
WickedBerry
Jun 21, 2009 06:52 PM
eskilm
Nov 4, 2006 09:04 PM
phil01ss
May 29, 2006 09:21 AM
jaleg
Nov 17, 2004 02:53 PM
