Fog Light Help
Old Apr 9, 2012 | 07:12 AM
InsanePyro's Avatar
InsanePyro is on a distinguished road
Default Fog Light Help
Recently I picked up some cheap fog lights just to get started with. I first ran them on my workbench power supply and they're actually pretty bright but I get them on my truck and they're dim.
I have wired them up like so
The original diagram is here Fog Light Wiring with Bosch Relay
The only thing I can see that may be dimming them is that I don't have them separately grounded. Any ideas?
Old Apr 9, 2012 | 09:50 AM
Rottidog's Avatar
If you have them properly wired to a relay, switch & power source then it's the ground. They should be grounded individually for them to work properly. When you 'bench tested' them they were bright so you know they work. Ground them & or trace the + power as well.
Old Apr 9, 2012 | 04:05 PM
InsanePyro's Avatar
Grounding them separately did the trick. Thanks!
Old Apr 9, 2012 | 06:36 PM
Rottidog's Avatar
Good to hear!
SWANNERZ
Aug 13, 2014 05:05 PM
TimmiT
Mar 10, 2008 12:01 AM
EuroGoldLS
Jun 15, 2007 04:11 AM
bat119
Aug 1, 2006 01:56 AM
Maxima570
Nov 22, 2005 04:06 PM
