Fuel gauge died & Low Level light on 98 Blzr
Old Jul 26, 2011 | 03:19 PM
stoneyj's Avatar
stoneyj is on a distinguished road
Unhappy Fuel gauge died & Low Level light on 98 Blzr
After topping off the tank on my 98 Blazer and only driving about 2 miles I noticed the fuel gauge reading Empty and the fuel low level light illuminated as well as the console readout of "E". I have confirmed the tank is still full as I have driven it and there is no evidence of a total fuel leak.
My thinking was that it was a fuse but I cannot determine which fuse it would be. No other lights or warnings in my intrument cluster are affected. Everything else seems to be fine.
Any idea where I need to begin troubleshooting?
Old Jul 26, 2011 | 03:54 PM
97cherryblazer's Avatar
97cherryblazer has a spectacular aura about97cherryblazer has a spectacular aura about
If you search "fuel gauge" I'm sure you will get plenty of helpful threads, I have seen a few that have discussed this. I would link you to some but I'm on the moble site so I can't.
Old Jul 26, 2011 | 03:56 PM
Have a look through the thread linked to below and let us know if you have some more questions:
98+ Fuel Gauge Diagnosis
The fuel gauge is powered along with quite a few other gauges in the cluster so a single fuse going out would tend to affect other gauges as well. Your problem is likely a wiring or sending unit issue. The diagnostic chart, even skipping over the scan tool stuff, can lead you to the source of the problem.
And as suggested, there are quite a few threads discussing problems with the fuel gauge, or more specifically the fuel level sending unit.
Old Jul 26, 2011 | 04:42 PM
stoneyj's Avatar
Thank you both.
Old Aug 18, 2011 | 11:09 AM
stoneyj's Avatar
Default Fuel additive is the culprit
After several tanks of gas the fuel guage began working again. I had put some STP fuel injector cleaner in the tank near the time the fuel guage quit. But after several tanks of gas it purged itself out.
serenity12723
Oct 12, 2011 02:44 PM
nofenders32
Apr 1, 2011 07:51 PM
mearltobias
TrailBlazer GMT360/GMT370 (2002-2009) Tech
Sep 19, 2010 04:06 PM
mfd70
Jun 4, 2010 05:26 PM
zoniah
Jun 2, 2008 08:45 AM
