low voltage guage
Old Aug 18, 2011 | 07:59 PM
98blazin's Avatar
98blazin is on a distinguished road
Default low voltage guage
my voltage guage reads about 11.5-12v, but when i read voltage with my DMM directly on the batt and alternator it reads 14.20v
if i roll down a window or use defrost at the same time i use the blower fan my lights dim.
anyonw knows why ?
Old Aug 19, 2011 | 07:40 AM
98blazin's Avatar
i would like to add that when cold, my guage reads 14v, but when hot it goes down to about 11.5v
Old Aug 19, 2011 | 08:47 AM
pettyfog's Avatar
Lights normally dim a little on extra load. Cant tell {us} by that.
The 14.2 on battery and alt shows your primary charging circuit is good. That is the conn between the engine block and battery.
Now you need to test the power distribution junctions. Follow the wires.. probe the terminal they connect to while lights/ac on.. etc. First place it's lower is sign of bad connection
Old Aug 19, 2011 | 08:55 AM
98blazin's Avatar
what do you mean by power junctions, and wich/where wires i probe ?
Old Aug 19, 2011 | 09:08 AM
pettyfog's Avatar
See the underhood fuse/ junction/relay? Start there.
Note you can probe tops of fuses for v to see if there's problem between there and batt positve..
2001Blue
Dec 31, 2010 12:16 PM
marketmagoo
Nov 21, 2009 02:09 PM
portcqb
Nov 3, 2009 06:40 PM
Fat_Phil
Aug 27, 2009 03:25 PM
Tdotblazer
Mar 26, 2009 01:00 AM
