Fuel Gauge going crazy!
Old Jan 7, 2018 | 07:16 PM
Nutbreezy's Avatar
Nutbreezy is on a distinguished road
Default Fuel Gauge going crazy!
alright guys I got a 97 blazer 4dr 4wd and the fuel gauge has not worked since I got the truck back in June 2016. It says its full all the time and then out of no where it will start dancing around and going nuts and by going nuts I mean it does full 360 degree circles and hits my volt gauge. I would prefer to test the wiring before dropping the tank I just haven't been able to find a wiring diagram that matches the wires going to the computer so if anyone knows how to go about testing the gauge and wiring that would be awesome!
Old Jan 7, 2018 | 10:05 PM
AJBert's Avatar
Very common for the sending unit in the tank to cause crazy readings. Very, very common.
Old Jan 8, 2018 | 08:11 AM
oldeerslayer's Avatar
oldeerslayer is an unknown quantity at this point
Here is a mitchell wiring diagram. Apparently it covers S-10 and blazer since it shows both ECM's in the diagram. Just pay attention to the lower one (VCM) for your blazer.
Old Jan 8, 2018 | 10:08 AM
Nutbreezy's Avatar
Alright so I would want to hook an ohm meter to the PPL/WHT wire for the fuel level signal and try rocking the truck back and forth to see if it changes? Also to check the ground wire to make sure its good would I put a meter on the negative battery cable and then to the BLK wire?
er0ck273
Sep 1, 2013 11:45 AM
jwalker1992
Jul 30, 2012 05:09 PM
614blazer
Sep 23, 2011 01:02 PM
02BlaserLS
Jan 6, 2008 03:09 PM
