fuel pump
Old May 22, 2012 | 02:55 PM
95redblazerelectrwhiz's Avatar
95redblazerelectrwhiz is on a distinguished road
Default fuel pump
Hey guys I had a quick question. Has anyone every years of the trailer lights being tied into the fuel pump circuit? I have had numerous problem when I plug in my trailer lights and my truck wont start. I narrowed it down that it was the fuel pump not turning on. Now last week my truck wouldn't start when I got out from work. Now having the problems I had before I went straight to the trailer wiring. I found that the ground for the trailer lights had broke due to corrosion. So I stripped it,reconnected the wire and truck fires right up. Has anyone heard of this?
Old May 22, 2012 | 03:58 PM
onebadsuv's Avatar
onebadsuv is on a distinguished road
Yes , My '95 2 door just recently started doing the intermittent connection thing where the trailer wire extension plugs into the truck wire harness - We've been getting alot of heavy rain every afternoon
(here in S.Florida) that may have forced the issue ... at first I went to the mini relays in the glove box but found a quick wiggle of the weather connector harness instantly brings the fuel pump to life . I'm thinking some di-electric grease to seal out moisture/water as a cure . Will test today
OK- got it done . Looks like on mine , the previous owner left the harness dangling and not completely snapped together either . There was no corrosion ... applied some D'lec grease and made sure the connector was fully seated . Also found the factory mount point to secure the harness/connector above the rear edge of the tank instead of hanging down exposed
Old May 22, 2012 | 06:59 PM
Do you know where they meet the fuel pump circuit at? I would like to just eliminate that problem and run them straight from the tail lights, or run all new wires from the beginning.
Old May 22, 2012 | 08:55 PM
onebadsuv's Avatar
I would suggest going to Your local pick-n-pull yard , find a suitable "donor" vehicle with nice , clean factory harness to replace the bad harness part in Yours ... cheap cost with best return to return factory running condition. If none (salvage yards) are local to You then consider other options.
BouncingRadical
14
Nov 27, 2015 12:30 AM
cide
Nov 7, 2009 01:26 PM
upblazer95
Mar 8, 2009 07:15 PM
Lckyctch
Dec 30, 2007 05:38 PM
mytruck2
Dec 13, 2006 04:50 PM
