Fuel Pump?
Old Nov 19, 2015 | 04:34 PM
Jimmy_Blazer's Avatar
Jimmy_Blazer is on a distinguished road
Default Fuel Pump?
Alright, 2000 blazer 4 door. The gas gauge shows full all the time, the fuel pump works fine, good pressure. Is this a common problem and if so, do I have to replace the whole fuel pump assembly? Thanks.
Old Nov 19, 2015 | 08:34 PM
richphotos's Avatar
That is most likely the sending unit that is causing that issue. There is a float inside of the tank that lets the gauge know how much fuel there is.
I would first start by checking the fuel pump ground.
When you are under the truck at the rear, find the fuel pump harness and there should be a ground wire from that harness that is bolted to the rear of the truck, usually in the middle of the frame cross member right before the bumper.
When you find it, take it off, clean the ground point and the bolt and the ground strap really well and put some dialect grease on it and bolt it back up and see if that fixes your problem.
Old Nov 19, 2015 | 09:54 PM
Toocute350's Avatar
Toocute350 is on a distinguished road
Like ritchphotos say"Check the ground".If the ground checks out o.k.?Then it`s the sending unit.You have to pull the pump out if and when you want to even see the sending unit.So if you want to spend the money to have your mechanic pull the tank?You might as well buy a whole new unit.Knowing your luck, you pull the tank,replace just the sending unit..The pump may fail the next day.Rule of thumb..If your in it..Replace everything there while your at it.Ex:If you have a bad upper ball joint on one side?You may as well change both of them.Because the one you didn`t change will eventually fail with time.Then you have to go back in and do the same thing over again.
BouncingRadical
14
Nov 27, 2015 12:30 AM
cide
Nov 7, 2009 01:26 PM
upblazer95
Mar 8, 2009 07:15 PM
Lckyctch
Dec 30, 2007 05:38 PM
mytruck2
Dec 13, 2006 04:50 PM
