fuses
Old Nov 3, 2011 | 04:17 PM
NEW YORK BOY's Avatar
NEW YORK BOY is on a distinguished road
Default fuses
hey, i have a 96 blazer and i have a fuse prob. turn and brake light fuse keeps blowing. why is this? can anyone help me this is my only ride. the fuse blow as soon as i put them in. plezz help!
thanks,
jeff
Old Nov 3, 2011 | 05:05 PM
xgiovannix12's Avatar
you have a short some where
IF you have a trailer plug id start there
Old Nov 3, 2011 | 05:50 PM
great what do i do with the plug what do you mean.. sorry dont know anything about wires
Old Nov 3, 2011 | 05:54 PM
follow it see if you got any burnt wires or any hot wires touching the frame causing the fuse to burn
Old Nov 3, 2011 | 05:55 PM
chris015's Avatar
Look for cuts in the wires that have power to them(hot wires)
Thogert's Avatar
I'd start with getting a DMM. (Digital Multi Meter)
Old Nov 3, 2011 | 05:59 PM
what is that whats it for?
Old Nov 3, 2011 | 06:09 PM
Thogert's Avatar
It can tell you if a wire has a short to ground in places you can't see or find. It makes looking a little easier, because you can test the wires without searching along the whole thing.
Old Nov 3, 2011 | 07:13 PM
alright thanks guys. if there is anymore tips plezz post them..
thanks for the help,
jeff
Old Nov 3, 2011 | 08:18 PM
pettyfog's Avatar
a 12 v test light will work just fine for this and it's easier to read.
First, which fuse exactly and where?
You say you fuse blows immediately.. does that mean as soon as you install it or when you use brakes?
When you probe the top contacts of a blown fuse the light will light when the shorted circuit is activated.
Say, for example, the short is just past the brake switch.. have a helper press the brake and light would light.
If it lights with key off and no switch active then short is likely between the fuse and brake switch
nineteensixtycaddy
Sep 12, 2010 08:54 PM
XBlazer01
Jun 20, 2006 05:18 AM
WIKKID1
Jan 6, 2005 03:48 AM
WIKKID1
Dec 21, 2004 06:36 PM
drewminator33
May 13, 2004 03:17 AM
