gas gauge
Old Dec 23, 2010 | 12:53 AM
mov4x4's Avatar
mov4x4 is on a distinguished road
Default gas gauge
So the needle in my gas gauge bounces when I stop and start and was wondering if that is caused by the gas "sloshing" around in my tank or if it is a sign of a bad fuel pump.
Old Dec 23, 2010 | 08:05 AM
I know on the newer trucks, the PCM buffers the signal from the fuel level sending unit. Not sure if that is the case on the older trucks. If the gauge reads accurately other than the bouncing, I'm not sure I would worry about it too much.
Old Dec 23, 2010 | 11:03 AM
rriddle3's Avatar
The needle movement will be more noticeable when the gauge reads ~1/3 tank or less. Above that point any movement would be barely perceptible.
Old Dec 23, 2010 | 12:24 PM
mov4x4's Avatar
Its accurate and everything I was just wondering if I should be worried about it.
Old Dec 23, 2010 | 03:12 PM
Tinted's Avatar
Tinted is on a distinguished road
lol i have a similar issue. when facing up hill i have alot more gas, but when facing down hill i have alot less
Old Dec 23, 2010 | 03:20 PM
mov4x4's Avatar
Haha yes and under hard acceleration you have more gas than you do stopped on a flat
Old Dec 26, 2010 | 04:06 PM
Rottidog's Avatar
I've noticed as Riddle said, that around 1/3 a tank it moves around a LOT. I also noticed that when it's around 1/4 tank & it changes radically, if I put it in neutral while at a light or moving steadily along, the needle bounces but goes up to the actual (so I hope) fuel level. Hows that for odd? lol
Old Dec 27, 2010 | 02:10 AM
mov4x4's Avatar
@Rottidog that is odd I've never tried as you described, might see if mine does that. How do you like your intake swap?
Old Dec 27, 2010 | 11:28 AM
Rottidog's Avatar
Intake swap was good... sorta lol
https://blazerforum.com/forum/showth...t=50638&page=5
Don't want to hijack the thread
grayman63
Jul 17, 2013 01:56 PM
98blazerb
Jun 20, 2012 09:53 PM
hoppy26
Jan 26, 2012 02:08 PM
starandrose
Sep 22, 2010 06:25 PM
Mulisha
Mar 24, 2008 09:14 PM
