Gauges and radio frustration
Open up the dash and make sure whatever spilled in there is cleaned up. Disconnect the negative battery cable and use electrical contact cleaner. Make sure everything is clean and tight then start the truck. Try to make it fail by wiggling different bundles of wire.
Ok Will do. Do you know of any other wire harness that is related to the gauges. And could there be a loose ground wire in the fuse block?
uncle_egg820
Jul 30, 2012 11:19 PM
rubeninfl
May 8, 2009 09:31 AM
