headlight or blower motor on high creates engine surge
Old Mar 26, 2013 | 12:24 PM
racechaplain's Avatar
racechaplain is on a distinguished road
Default headlight or blower motor on high creates engine surge
Has anyone had an issue in which when you turn your headlights on that the engine rpm drops like 2-300 rpms. I noticed that if I have my heater on high fan, warming the truck up obviously in frigid IL temps, and then go to turn on the lights, the idle surges instantly. I changed the battery and the altenator and it still does this. The engine idles fine when the lights are off and the heater is also off. weirdest thing I have seen!
I checked the grounds and ended up replacing the ground cable for the battery and cleaning the connection points. I also redid the ground on the rear crossmember for safe measure but it still spikes voltage somewhere...
This is a 1996 Blazer LS 4 door auto with 4.3
maxvamp
Oct 31, 2020 08:19 AM
phily9
Jun 5, 2011 12:20 AM
Gearhead52
Feb 21, 2011 02:50 PM
dbleon
Mar 17, 2008 09:29 PM
Blazer96
Mar 18, 2006 02:09 AM
