Headlight Settings Help
Old Aug 8, 2011 | 01:37 AM
BigEffingHammer's Avatar
BigEffingHammer is on a distinguished road
Default Headlight Settings Help
Hey guys, I've ALWAYS been confused with the lights panel and the three settings...
So, there is, let's say, position 1, 2, and 3.
When I first got this Blazer, I tested all 3 out, during the day, and during the night.
Position 1: DRL's
Position 2/3: Low beams (no difference between the two)
Both were the same for during the day/night.
Now, few months ago...
Position 1/2/3 daytime AND nighttime were all lows
Now, just today, as I was driving home IN THE DARK, I had it set to position 1, and out of nowhere, every headlight/DRL turns off and I nearly sh*t my pants considering I could not see a single thing while driving 65ish, so, I turn to position two... Incredibly dim lights (maybe the DRL's?), then I turn to position three, normal lows.
So, can someone please explain what each of the three positions are supposed to do during the daytime and nighttime?
Also, fun fact... For a while, leaving lights in position 3 and having door open would make it ding. Then, for a while, that dinging went away, and now, it's back again tonight. I've checked the connection between the panel/harness, no problems there.
Anyway, please and thanks.
Old Aug 8, 2011 | 07:58 AM
Check out these pages from the 2002 Owner's Manual:
Old Aug 8, 2011 | 11:58 AM
Thanks for those pages. I always forget to look at the manual.
So could this possibly be my sensor breaking or whatever activates by pushing the dome overdrive 4 times acting up?
Old Aug 8, 2011 | 12:04 PM
The dome override trick doesn't work on all of them. Used to think it was the Canadian spec truck that had this feature turned off for some reason, but the more people that spoke up about it in a thread from a long while ago, the more random it appeared.
If your dome override button works properly (ie. turns off your interior lights so they don't come on when the doors are opened), then it likely isn't programmed to turn off the lights like others are.
Old Aug 9, 2011 | 10:42 PM
Well, figured it out. The dome override trick does work on my Blazer, and it must be that thingymabob screwin' up. What is it that controls that with the 4 pushes?
Also, the dome override DOES work properly.
Thanks for the help.
Mudlife88
Oct 5, 2011 12:02 PM
matt92
Feb 28, 2011 11:08 PM
Cobra102000
Feb 3, 2011 02:55 PM
rdavis
Dec 23, 2008 03:00 PM
nofear17bmx
Nov 30, 2007 09:46 PM
