Headlights quit working
New to this forum and would be grateful for your help.
I have a 97 Blazer 4 dr 4x4. My headlights quit working a while back, so I was using my high beams. Now my high beams quit working. I put in a new dash rocker switch with no luck. I also swapped the relays in the glove box. Still no luck. My daytime lights work, as well as the parking and dash lamps.
I seen a post from 2011 that mentioned a bi-metal connector or something, that fixed an identical issue. Anyone know what or where this is. Any other help would really save my bacon.
There was recently a post that another member fixed his low beams not working by replacing the multi function switch.
I had issues with my low beams not working in my 2002 which turned out to be a burnt wire in my under hood fuse block plug.
This is the other members thread.
https://blazerforum.com/forum/lighti...-blazer-98399/
dusktiger
Oct 9, 2014 11:12 PM
