Headlights vs Light bar
Hey guys
I'm not happy with the amount of light coming off my blazer. I was thinking about getting a light bar and mounting it behind the grill. I also had the idea of getting better headlights like leds or hids. What would you rather go with and why?
Thanks guys, I appreciate your help
I've been super happy with my HID retro (FXR's, oem 35w parts), way better lighting in every aspect. But HID's in reflector/stock housings is a big no no. Having said that, I do have 2 32", and 1 42" LED bars to install. However those will be for off road use ONLY, or when I see someone with PNP HID's
Thanks
Absolutely never use LED's in your headlights. They have not come nearly far enough to make anything worth a damn in the aftermarket scene unless you retrofit some LED lights from a car that came from the factory with them. You will blind people most likely worse than you would with HID's in the housing.
You cant put either HID or LED into stock housing because they distribute light differently, their light needs to be focused. Where the stock housing was designed to properly aim the halogen bulb in the area it need to be with the various reflection points and the way the bowl is shaped.
You wont find a housing made to just install in a blazer that is made for HID or LED. Sellers, especially on ebay will say that it is indeed made for LED or HID and even sell a LED or HID bulb light kit with it, but its not made for those bulbs and they are just trying to get you to buy the product.
The only way to get LED or HID bulbs in a housing is to retrofit them in there (taking the housing apart, and installing HID projectors, or figuring out how to install LED projectors for a new car that came from the factory with them)
A good sit to visit is www.hidplanet.com
