Heater control works with key out
Old Dec 28, 2017 | 04:19 PM
radhazard1's Avatar
radhazard1 is on a distinguished road
Cool Heater control works with key out
Anyone have their heater controls still work even with the key out? 2001 Blazer. Until I pull the #9 inside dash HVAC fuse, I can use all controls of the HVAC.
Old Dec 28, 2017 | 05:05 PM
Heater controls I think are intended to work via the Retained Accessory Power (RAP) circuit for up to 20 minutes with the key out as long as a door is not opened. This applies to the radio too. Does the radio also work when the heater controls work?
Perhaps the RAP circuit/replay has a fault?
Old Dec 28, 2017 | 05:13 PM
radhazard1's Avatar
Of course I mean with the door open. I know they can stay on with only the key out before you open the door. I'm talking all the time until it kills that battery unless I pull the HVAC fuse. Or I can turn the control off but still turn it back on while the key is still out.
Old Dec 28, 2017 | 05:15 PM
Strangerock's Avatar
Strangerock is on a distinguished road
If you find someone with a Tech II , Im pretty sure you can check the RAP unit out .
Old Dec 28, 2017 | 05:20 PM
OK, that is why I asked. Yes, it should turn off once the door is open or after 20 minutes.
So does the radio also work even with the door open? Will the HVAC controls work longer than 20 minutes? (From what you wrote I'm assuming the answer is 'yes.') Does the dome-light come on when the door is opened?
I ask to see if the RAP circuit is working correctly or not. Also, I am wondering if the door jam switch is not working so that the RAP circuit "thinks" the door is still closed.
Old Dec 28, 2017 | 05:37 PM
radhazard1's Avatar
I am pretty sure it is the ignition switch so I'll change it tomorrow and see how it works. I did have it unplugged and the HVAC stayed on though but I have found a couple post about that being the problem. I'll let everyone know tomorrow!
Old Dec 28, 2017 | 08:52 PM
odat's Avatar
My guess stuck / bad AC relay
Old Jan 2, 2018 | 03:51 PM
radhazard1's Avatar
Ignition switch not the problem. Relay good also.
Old Jan 2, 2018 | 05:09 PM
rockp2's Avatar
Do you have the automatic or manual HVAC system?
Old Jan 3, 2018 | 12:49 PM
radhazard1's Avatar
It is manual. Not the resistor and does not have the blower module.
changeme20
Oct 24, 2020 02:12 AM
kap777
Nov 22, 2013 08:13 PM
tpolzin
Aug 30, 2012 09:34 PM
Cidium
May 6, 2011 06:38 PM
rsterrn
Nov 15, 2010 08:53 AM
