Heater is running, key is out?
Old Oct 11, 2013 | 11:16 PM
kap777's Avatar
kap777 is on a distinguished road
Default Heater is running, key is out?
Mine is a 1997 Blazer 4x4. I can turn off key, take key out and radio and other accessories are off, heater is still running. I've had dead batteries because the heater fan does not turn off. Only the heater can run with the key out of the ignition switch. Any experiences? Is it the key switch or the heater relay or who knows?
Old Oct 12, 2013 | 08:38 AM
rexazz2's Avatar
my thought would be relay stuck
Old Oct 13, 2013 | 10:34 AM
abig84's Avatar
ive seen this a couple times on the fullsized trucks. both times its been the blower motor resistor. most the times those go out you usually lose a speed or two but have seem them cause the vehicle to keep the fan on
Old Oct 13, 2013 | 07:52 PM
kap777's Avatar
I should refine exactly what happens. I can control the fan speed with the key off. I have to turn off the heater/AC or the fan will run, unless I just turn the fan down to off.
Old Oct 14, 2013 | 08:27 AM
rexazz2's Avatar
take a look in the fuse panel for a relay marked HTR
Old Nov 2, 2013 | 09:58 PM
kap777's Avatar
Default Problem resolved
Turns out it was the ignition switch. Pretty easy to do, but you need a special #4 female torx long socket to do it (Amazon). Thanks to everyone for chiming in, hope this helps someone else.
Old Nov 3, 2013 | 12:15 AM
rexazz2's Avatar
thanks for the follow up
often we never hear the out come
Old Nov 22, 2013 | 08:13 PM
Catfishguy's Avatar
Catfishguy is on a distinguished road
Ive had the same issue. Thos was a great help
changeme20
Oct 24, 2020 02:12 AM
50lb_cat
Oct 3, 2017 03:40 PM
Kevin Cody
Jun 30, 2013 07:28 AM
49er_Dirtbag
Jan 14, 2010 06:43 PM
pigmak
Nov 26, 2006 06:02 PM
