hid conversion to stock headlights
Old Aug 25, 2012 | 06:13 AM
Thogert's Avatar
Well you wouldn't need the headlights in the link you posted unless you really want that look instead of the stock lights.
The only big thing you would need to buy is the projectors which you can find here.
Theretrofitsource.com
That is the link to the Morimoto mini H1 projectors, which should work fine for your application.
Here is a link to a how-to for the MH1. I'm not sure how deep the stock headlights are, but it might not be quite so simple if it won't fit.
You can check out the retrofits section on hidplanet to see how the pros do theirs, and go from there. Feel free to ask any questions you might (probably) have.
Old Aug 25, 2012 | 10:41 AM
Logan's Avatar
Logan is on a distinguished road
Yes, do not run HID's without the proper projector. 2 people here learnt that the hard way. One guy in a cavalier was behind my old boss and his headlights were blinding. So my old dutch boss slammed on his brakes, got out of his truck, and smashed the guys lights with a hammer. The other guy same thing with with a civic. Some people have zero tolerance for that crap.
Old Aug 29, 2012 | 02:56 PM
neo71665's Avatar
Lmao I like that guy.
Old Sep 2, 2012 | 09:48 PM
jeff663's Avatar
jeff663 is on a distinguished road
hey i tried searching for this but couldn't find it anywhere.. anyway im going to be buying a 6k hid kit for my 2005 2door blazer and was wondering what bulb type i need, i heard 9005, 9006, and 9007. Also what size would I need?
Old Sep 3, 2012 | 02:33 AM
Logan's Avatar
I believe our low beam is 9006... Ill look tomorrow.
Old Sep 3, 2012 | 09:21 AM
Chris1600's Avatar
Chris1600 is on a distinguished road
The low beams are 9006 and the high beams are 9005.
Old Sep 3, 2012 | 09:29 AM
Rottidog's Avatar
But some HID kits use a (9005) high beam HID in place of the (9006) low beam, because it's focused in a projector I assume. I know mine use a 9005 in the low beam.
Old Sep 3, 2012 | 10:13 PM
DennisRR's Avatar
DennisRR is on a distinguished road
Default HID Headlight Conversion.
I just converted my sealed beam headlights to Conposite Headlight housings from ANZO USA Anzo USA - Performance Lighting and then I replaced those Halide Bulbs with HID Xenon Balasts and Bulbs from HID Lights HID Kits Xenon Headlights Kit HID Headlight Kits HID Conversion Light HID Xenon Headlight conversion Kits.
It made a huge difference. The only problem I am having now is that my current setup is either dim bulbs or high beam bulbs. Xenon Bulbs have a slow on time of maybe 15 or 20 seconds before they reach full brightness.
I want to know if anyone knows of a way to have all bulbs lit up when the switch is High Beams and then only the dim bulbs lit when the high beams are switched off. If anyone could help me with this I greatly apprieciate the help.
Old Sep 3, 2012 | 11:50 PM
Thogert's Avatar
If you do a search on here for 'high 4 mod' you should be able to find your answer (if I understand the question right).
hollywoodgrad
Jan 25, 2012 01:58 PM
ohsofly
Jan 7, 2012 02:25 PM
reporob
Jun 3, 2010 02:48 PM
Indo G
Dec 4, 2008 10:40 AM
jagblazer01
Mar 9, 2006 10:43 PM
