HID & DRL at same time?
Old Jul 14, 2013 | 07:25 AM
Blade_24k's Avatar
Blade_24k is on a distinguished road
Default HID & DRL at same time?
2000 gmc jimmy 4x4 4-door. I got 8000k HIDs with the 55 watt power series ballast and the hid relay wire harness from hidextra.com.
Today I noticed my passenger side hid was on with my DRL's.
I modded the Auto headlights with the 2.2k ohm 1/2 watt resistor in the sensor. Quad beam by grounding the yellow without the black stripe wire on the driver side.
Do I simply need to disable my DRLs?
And if so I thought I read somewhere that doing all 3 of these mods togeather causes something to mess up or not work?
Plus does anyone know what would cause the hid to come on with the DRLs?
Old Jul 15, 2013 | 09:39 AM
Blade_24k's Avatar
Ok update, im trying to disable the DRLs, I tried to pull the relay (didn't work), tried to bend pin #86 (didn't work), then I tried to bend all but #87a and #30 (didn't work). Well I guess I shouldn't say it didn't work as it made so my lows are my DRLs.
Im aware i can just do the hit the dome overide button 4-5 times and read that it doesnt work on canadian models. And it does work on mine, but I want a permanent disable.
Old Jul 15, 2013 | 10:36 AM
richphotos's Avatar
what about pushing the parking brake in a couple clicks?
Old Jul 15, 2013 | 12:17 PM
Thogert's Avatar
This is why I like my cobalt drls. One fuse.
TheJohnnyRaygun
Jan 17, 2012 04:13 PM
mikepro
Aug 15, 2011 07:03 PM
AmberRose
Aug 30, 2010 08:58 PM
blazinUP
Nov 22, 2008 10:39 PM
EuroGoldLS
Feb 28, 2008 11:03 AM
