HID Issues
Old Aug 30, 2010 | 05:05 PM
pj5454302's Avatar
Default HID Issues
Ok heres the problem, sometimes the hid's in my kc daylighters just flash. Now my setup has a relay so thats not the problem, and sometimes it will work fine and other times it will just flash. So I have checked the fallowing, ground, power wires and switch. When they flash I can flip the switch like 30 times and they will work, now i know this is bad for the balsts but they have a life time warentee so if they break ill send em in. I dont think its a blasts or bulbs because after the switch flipping they work fine.
And suggestions?
Old Aug 30, 2010 | 08:48 PM
Blazin_Jason's Avatar
You can always swap the bulbs from side to side and see if it's still acting the same. I would guess though that the ballast is on it's way out. ddm?
Old Aug 31, 2010 | 06:00 AM
pj5454302's Avatar
Yeah its ddm, and when it acts up both sides flash. Also would hope a ballast isnt going out just put the HID's in the end of july.
Old Aug 31, 2010 | 05:06 PM
pj5454302's Avatar
Well replaced 25 amp relay with 40 amp one and no change. Had a spare set of ballasts so when it was acting up swaped them out and they fired right up. But after I swapped the original ballasts back in and they also fired right up so im stumped.
Old Aug 31, 2010 | 05:12 PM
Ryanmatt135's Avatar
Ryanmatt135 is an unknown quantity at this point
if i were you i would back probe your power and ground circuit at the connector to the ballast and compare that voltage to the same connector(s) when it working correctly and see if theirs a voltage difference.
Old Aug 31, 2010 | 06:31 PM
pj5454302's Avatar
Will have to try that.
Old Aug 31, 2010 | 08:54 PM
MTopper's Avatar
Also, if you bought the raptor kit from ddm ($30 kit), they aren't the best made kits out there so you could possibly have gotten a funky set. my set i had in my headlights went bad and nearly caught fire (i had a thread about it, the bulbs would glow bright orange/red after being shut down for 20 minutes). my last kit had a flashy "right" ballast where the head light flickered if i was in gear.
worst case scenario, you buy a new kit for $25
Old Aug 31, 2010 | 08:55 PM
DDM does have a lifetime warranty.
Old Aug 31, 2010 | 09:06 PM
MTopper's Avatar
Yes they do. but they jerked me around when i called as my thread said back in March.. so, hopefully he gets his figured out or replaced with no hassle and can post the repaired photos
Old Sep 1, 2010 | 07:29 AM
pj5454302's Avatar
Ill try giving them a call today after class.
LuvMyTJ
Apr 22, 2010 09:59 PM
drperry
Jan 13, 2007 07:27 PM
kaindragoon36
Dec 1, 2006 08:01 AM
jagblazer01
Mar 9, 2006 10:43 PM
blue_green_rider
Feb 7, 2006 10:44 AM
