HID Lights connections
Old Mar 7, 2010 | 09:46 AM
Gary99's Avatar
Gary99 is on a distinguished road
Default HID Lights connections
Just installed the low beam HID lights in my 99 blazer that I purchased from HIDextra. In order to get them to turn on, I have to first flash my high beams on and off. Is this normal or did I do somthing wrong here?
Any suggestions would be much appreciated.
Thanks
Old Mar 7, 2010 | 04:33 PM
I'd say something is wrong. It might not be you though. How good are you with a multimeter? Do you have some back probe tips? If you have a multimeter and some back probe tips, you can see if it is something wrong with the original wiring or with the ballasts themselves. I would bet that the problem is likely with the ballasts.
Did you hook them up direct or did you use a relay kit? Are both sides doing the same thing?
Old Mar 7, 2010 | 04:36 PM
wlorton's Avatar
I would go ahead and call HIDextra if you purchased the kit from them... From the looks of it they run one hellla of business and will fix your problem...
Old Mar 7, 2010 | 05:51 PM
Gary99's Avatar
I don't have a multimeter and to be honest would not know how to use it properly.
Have to flash the high beams to get both HID low beams to come on. As the HID's turn on they flicker a very little bit - is the normal?
Old Mar 8, 2010 | 01:18 AM
Jonas's Avatar
Jonas is on a distinguished road
Default RE
Sounds like lack of power,
try reving the engine some or be driving as you start the lighs.
rastoma
Oct 7, 2009 05:57 PM
95LS
Aug 26, 2009 05:57 PM
gstxtt
Jun 24, 2009 12:08 AM
Bob97
Jan 4, 2008 09:20 PM
Talusgirl
Jul 29, 2007 03:21 AM
