HOT switch
Old Jul 26, 2011 | 02:18 PM
G.I. joe's Avatar
G.I. joe is on a distinguished road
Default HOT switch
Hello all,
Recently I installed a set of fog lights on my bumper. All the wiring was done correctly and connected to a switch in the interior. After the lights have been on for a few minutes, the switch gets hot.
It won't burn you but its very warm. Is this supposed to happen? why is my switch hot?
Thanks
Old Jul 26, 2011 | 02:33 PM
You have to size the switch properly for the load that the circuit will be flowing. A good way to keep the switch happy & cool is to install a relay to the light. Relays require very little current to activate. Check out the12volt.com for info on relays & how to wire them.
Old Jul 26, 2011 | 04:15 PM
mdehoogh's Avatar
Here's a good diagram I just found for a circuit that will work for you. A relay is an electrically operated switch and they're typically rated for more amperage than a standard SPST toggle switch.
If you'd prefer not to add a relay and redo the wiring, make extra sure you have a fuse (so your switch doesn't catch on fire some day) or try and find a switch rated for more power.
stevenhousden
Jul 6, 2014 05:56 PM
hzl6cm
Mar 7, 2012 07:30 PM
Mandrwj
Apr 10, 2011 07:32 PM
88_s10
Jan 15, 2011 05:04 PM
ravenhurst
15
Apr 26, 2009 07:53 AM
