How do i switch the ignition lock on my blazer?
Old Sep 6, 2011 | 06:31 PM
pablo420's Avatar
pablo420 is on a distinguished road
Default How do i switch the ignition lock on my blazer?
Im trying to switch the old ignition lock on my 96 blazer because the key doesn't turn anymore. I tried putting WD-40 to see if it'll turn but it didnt. I have four keys and none of them work. So i bought a new ignition lock to replace it. I took off all the panels on the dash and the steering wheel to take it the lock cylinder off. Yes i disconnected the battery so the air bag wont come out. It seems like the steering wheel is int the way of the metal box holding the ignition lock it so i can get it out or unscrew it from inside. what should i do next and go about switching locks? any help would be greatly appreciated
Attached Thumbnails How do i switch the ignition lock on my blazer?-imag0097.jpg   How do i switch the ignition lock on my blazer?-imag0099.jpg   How do i switch the ignition lock on my blazer?-imag0101.jpg   How do i switch the ignition lock on my blazer?-imag0104.jpg   How do i switch the ignition lock on my blazer?-imag0109.jpg
Old Sep 6, 2011 | 06:48 PM
Vehicle details?
Old Sep 6, 2011 | 07:05 PM
pablo420's Avatar
its a 1996 chevy blazer LT
i also added pictures so you see what ive done already
Last edited by swartlkk; Sep 6, 2011 at 07:29 PM. Reason: *Combining Consecutive Posts* - Please use the edit function to add additional information in your post if another member has yet to respond.
Old Sep 6, 2011 | 07:54 PM
What did you do to that thing??
The removal of a lock cylinder that cannot be turned requires removal of some tabs with a die grinder. If you are not comfortable doing this procedure, it is best left to someone who is.
If you can get the cylinder to rotate to the start position, it is simple to remove. Find the hole on the top of the housing that the cylinder resides in and insert a 1/16" allen key into the hole and allow it to turn back to the run position. The cylinder should then be released and allowed to be removed.
Old Jan 13, 2013 | 06:02 PM
wannabelifted's Avatar
wannabelifted is on a distinguished road
can u guys tell me if these steps will be the saem for a 93 blazer??
Antne
Aug 29, 2014 05:59 PM
mkm1387
Jan 10, 2013 05:12 AM
robbh432
Jun 20, 2012 08:55 PM
JeffUSMC
Jun 25, 2010 09:08 AM
Booztd
Jun 6, 2007 11:13 AM
