how do you align too low headlights?
Old 07-29-2015 | 07:46 PM
puttster's Avatar
puttster will become famous soon enough
Default how do you align too low headlights?
I fixed my headlights (pointing too high, see fix below) but now they point too low. I see a torx screw just above them, flanked by two hex screws. Is the torx the adjuster?
Puttster
"On my new to me 2002 Blazer it seemed the headlights were too high. I wanted to align them before going in for inspection. I found this forum and everything I needed to fix the problem. It was all very satisfying!
PO had replaced bulbs but did not insert the lower tabs of the headlight assembly into their slots. So, following instructions found here, I unsnapped the grill (held on by clips only) and I could see where the tabs were not in their slots. On the frame behind the lights (in front of the battery) are two vertical tabs about 6" long. To remove the assembly, pull them up and it falls out. To reinstall, put it back, with the lower tabs in their slots, replace the 6" tabs, line up the clips on the grill and push it back into place. DONE! "
Old 08-01-2015 | 09:29 PM
benjusa's Avatar
benjusa is on a distinguished road
The Torx screw is the one you want to use to adjust your headlights. There should be one for up and down and one for left and right.
Old 11-14-2015 | 09:50 PM
pmanwarren2015's Avatar
pmanwarren2015 is on a distinguished road
what if the place where you put the clips are gone can it still be fixed ?
Old 11-17-2015 | 08:37 AM
puttster's Avatar
The clips that hold the grill on?
Old 11-17-2015 | 09:07 AM
Toocute350's Avatar
Toocute350 is on a distinguished road
I`m not sure,but I would help you if I could,i`ve never had to worry about this not just yet.
cferry7
10-15-2013 04:19 PM
patterrr
04-02-2011 11:09 AM
blzn95
01-14-2009 10:20 AM
DerCribben
11-15-2007 07:41 PM
DSBenson
17
04-29-2007 05:54 PM
Quick Reply: how do you align too low headlights?
