Interior LED replacement guide
Old Nov 15, 2013 | 12:28 AM
Thogert's Avatar
I've never personally had the opportunity to work on, or look at a K5, but if anyone here has some experience, it would be great info.
Old Nov 29, 2013 | 11:06 PM
CYPH3R's Avatar
CYPH3R is on a distinguished road
Thanks! i just ordered all blue intrument back lights and white dome lights and license plate lights. super easy with the web site and this thread as a reference!! will post before and after pics When i can
Old Dec 17, 2013 | 02:11 PM
Willmsy's Avatar
Willmsy is on a distinguished road
So the defog, wiper and hatch button lights are 4mm neo wedge types on a 1995 blazer that is Canadian. Just ordered up all these lights according to your specs just to realize they are wrong.
Old Dec 17, 2013 | 06:34 PM
Vader's Avatar
Vader is on a distinguished road
Where in Alberta are you? What site did you order the LEDs from?
Old Dec 17, 2013 | 08:50 PM
Thogert's Avatar
Ok, what kind of bulbs does it need if you wouldn't mind?
Edit: Doh, sorry, I'll put that in.
Old Dec 18, 2013 | 05:39 AM
Willmsy's Avatar
I'm from Red Deer, and I used super bright LEDs.
Another note I would make is for the 1995-97 blazers, in the 4x4, switches, you have to take out an orange lens. If you get a pick or small screwdriver you can work at it from the inside of the switch and it will eventually come out. I chose blue for my 4x4 switches, and holy hell is it ever bright. I cut up a clear plastic bag and put a couple layers between the led and the lens to dim it down, you may want to do the same.
Old Dec 19, 2013 | 11:07 PM
Thogert's Avatar
Oh yeah, I forgot to add that in this post. I think I had it in my original one, but maybe not. Thanks again. I actually used masking tape that was the same color on mine.
Old Mar 24, 2014 | 05:26 PM
packrat1969's Avatar
packrat1969 is an unknown quantity at this point
Default LED Replacement Dimension Questions...
When you are referring to 3mm, 4mm, and 5mm LEDs, just what dimension is that? The diameter of the socket? The diameter of the lamp? The length of the lamp? I have measured all of the dimensions on the bulbs and sockets that came out of my '99 Blazer's driver door switch assembly (power windows/door lock, etc) with a digital micrometer, and none of the numbers are close. Are you rounding off.
Thanks for any info you can provide...
packrat
Old Sep 27, 2014 | 11:31 PM
DocMcBuff's Avatar
DocMcBuff is on a distinguished road
Default LED for exterior
Would LED lit license plate frame work on a 98? What about changing the license plate sockets to LED. I can't seem to get my license plate lights working.
Old Apr 6, 2016 | 03:20 PM
moosehauler05'blaz's Avatar
moosehauler05'blaz is on a distinguished road
194 Gauge bulbs Note: you dont need to buy the twist locks The gauge panel already has the Stock ones inplace swap out the new LED bulbs with the old twist locks
Anyone know the Bulb size for the gear selector? i'm guessing 174
