Interior LED replacement guide
Old Oct 24, 2018 | 04:28 PM
  #31
Originally Posted by duke54
how do you disassemble the 4x4 controller to put in leds to replace yellow colored one. just a strip of clear plastic I see. Thanks
Those are solded to the board inside the switch. You would have to desolder the LED's that are in there now and solder in your new LED's of the color you want.
Old Dec 2, 2018 | 12:45 PM
  #32
Maverick338369's Avatar
Maverick338369 is on a distinguished road
This may sound dumb, but can someone tell me where the footwell lights are located on a 2000? I have an open square section on an under dash panel on each side, but there are no sockets there.
Old Jan 24, 2019 | 08:51 PM
  #33
dlamb0726's Avatar
dlamb0726 is on a distinguished road
Default Clarification on Cluster LED Upgrade
Hello! The list of light was very informative. However can someone please just clarify for me that the 2002 Blazer LS uses the twist locks? If I buy the locks there's no soldering correct?? Just plug and play??
Old Jan 25, 2019 | 04:41 AM
  #34
GreenBlazer2002's Avatar
yes, twist locks. But you may have to twist the new ones only about 3/4 of the way. Many, including myself, have found that turning them all the way to the point where they lock is too far for the contacts to connect. Experiment with your bulbs. Also, if they don't work at all try tuning them 180 degrees. LED bulbs are polarized.
Old May 1, 2019 | 02:43 AM
  #35
SShadow1974's Avatar
SShadow1974 is on a distinguished road
Do you need to use resistors along with any of these LEDs? I have a 2001 Blazer LT and need to replace soldered bulbs in my AC control and in my door panels.
Old Nov 17, 2019 | 04:57 PM
  #36
Brian Wolfe's Avatar
Brian Wolfe is on a distinguished road
Smile Driver Side Footwell Light Location?
I am struggling to find the driver side footwell light, Does anyone know where the driver side footwell light is or have a picture of where it is on a 2003 Chevy Blazer? Any help would be appreciated!
Old Sep 30, 2020 | 06:42 AM
  #37
Massimo Andreello's Avatar
Massimo Andreello is on a distinguished road
Default How to dismount dashboard
Hello,
does anyone have a sort of dismounting manual to help substituting lights with led inside car? Iam kinda new and I wouldn't destroy my baby while attempting...thanks a lot for your help guys!
Old Sep 30, 2020 | 11:21 AM
  #38
Originally Posted by Massimo Andreello
Hello,
do you mean the piece around the radio and cluster? Or the entire dash itself?
theres a couple of videos of YouTube that can take you step by step.
Old Apr 6, 2022 | 03:11 AM
  #39
PhantomDiesel's Avatar
PhantomDiesel is on a distinguished road
What led size bulb does the rear passenger interior lights fit? As well as the trunk?
Old Aug 21, 2022 | 12:06 AM
  #40
Default Trunk stock bulb to led
Hey y’all I’m looking to replacing the stock trunk bulb with warm white led, what size am I looking for?
also the stock bulb is the Christmas light fuse looking bulb.
