Leaving rear glass open on ‘01 Jimmy kills battery
Old Jun 23, 2023 | 10:53 PM
Musgrove's Avatar
Musgrove is on a distinguished road
Default Leaving rear glass open on ‘01 Jimmy kills battery
The interior lights are overridden and off, so it’s just the “security” feature that I can tell is pulling on the battery. But if left open for a day or so, it drains the battery.
Is there a way to avoid this? I didn’t see a fuse to pull and with the interior lights off, I see no reason to kill the battery to have the back open.
any ideas and help are appreciated!
Old Jun 24, 2023 | 11:09 PM
GeorgeLG's Avatar
If there are no lights on then it must keep the BCM awake and creates a parasitic draw. There are 4 fuses that feed power to the BCM. I believe that the TBC fuse in the UHFB is the main power. You could try pulling that fuse to see if the problem stops.
George
Old Jun 25, 2023 | 01:51 PM
Musgrove's Avatar
The rear hatch is electric, which is what’s doing it. If the battery’s off there’s no way to open the glass! The fuse situation you describe is over my head so I’ll just leave it alone. I have bigger fish to suddenly fry with an ac blower that won’t ever cut off now.
Old Jun 25, 2023 | 03:02 PM
GeorgeLG's Avatar
Yes I am aware that the rear glass release is an Electromechanical mechanism but it should not be drawing current except to release the glass. I’ll stand down since it sounds like you’re not focusing on this right now. Are you asking for help with your blower motor?
George
Old Jun 25, 2023 | 03:46 PM
Musgrove's Avatar
Default Possibly related?
Well I wonder if this electrical bug is the cause of this too? My ac blower stays on after the keys left the ignition. The ac controls do nothing. Im having to disconnect a very hot battery quickly or else it drains the battery. I have an optimum yellow top, which I think is great but something else is going on.
Old Jun 25, 2023 | 07:55 PM
GeorgeLG's Avatar
Are you wanting help diagnosing your problem? Do you have a multimeter or an amp clamp meter?
George
Old Jun 25, 2023 | 08:14 PM
Chevymec's Avatar
Chevymec is on a distinguished road
Unplug the blower motor resister. If it stays running I think there is a high speed relay for the blower motor, it may be stuck.
Old Jun 25, 2023 | 09:28 PM
Musgrove's Avatar
Default You are brilliant
I was trying to figure out what to do, when it suddenly stopped, as it began. I think it may do it again though so your suggestions are highly appreciated. That’s a sticky situation. And that engine bay gets HOT on days like today.
lathechips
Nov 7, 2021 09:26 PM
babeba67
Jan 15, 2014 09:00 PM
Ayoo_dro
Jan 5, 2013 02:06 PM
Charleen53
Nov 3, 2009 02:06 PM
Windir
16
Nov 15, 2007 08:55 AM
