led lights
Old Aug 20, 2013 | 06:03 PM
glenny15's Avatar
glenny15 is on a distinguished road
Default led lights
ok so I put in all new led blubs in the blinkers and they all turn on when I turn the headlights on and turn the blinker on they do not blink at all. when the headlights are off everything works. I put a new relay in for the led's any1 have any suggestions on what the problem could be
Old Aug 20, 2013 | 06:08 PM
richphotos's Avatar
Plug and play LED's is the problem. They are usually made really horribly. and a lot of vehicles do not like them. Sorry to say.
Old Aug 20, 2013 | 09:43 PM
gitch93's Avatar
gitch93 is on a distinguished road
i have full leds in all my turn signals and rear lights u need to sometimes reverse the led bulb so it will work in conjunction with everything
Old Aug 21, 2013 | 06:47 AM
glenny15's Avatar
they all work when the headlights are off but once I turn the headlights on they wont blink for the blinker.
Old Aug 21, 2013 | 07:04 AM
richphotos's Avatar
That is a good thing to try gitch... if that does not work, There is nothing you can do but try a different brand of LED bulbs. PNP LED's are hit and miss when it comes to quality, mostly, miss.
Old Aug 21, 2013 | 08:44 AM
glenny15's Avatar
what is a gitch
Old Aug 21, 2013 | 09:18 AM
AndrewO1991's Avatar
AndrewO1991 is on a distinguished road
i got some a while ago that didn't work right, it was like running a single phase bulb. Full power when running lights are on, no difference when brakes are applied. Also they got super hot so i took them back out
Old Aug 21, 2013 | 10:32 AM
richphotos's Avatar
Originally Posted by glenny15
what is a gitch
That persons username that I was responding to.
Old Aug 21, 2013 | 04:14 PM
Thogert's Avatar
Yeah the blazers use a different wiring tactic to get the side marker lights on the front to get them to flash with the signals and act as a running light as well. So even if you get the main signals working, the side markers will only act as one or the other. I can go into more detail if you want, but I doubt it.
Old Aug 22, 2013 | 08:30 AM
gitch93's Avatar
Gitch is my nick name my friends gave me it is also my user name. I garuntee the leds will work. I have a 2000 jimmy and I used front led amber signals,front white led marker lights,rear leds brake lights and running lights,led lisence plate lights, I had issues when installling them u need to have the truck running and lights on to install the leds the roight way some of them u put in wrong and will cause the signals to not work so u may need to reverse the order u installed them
erik102207
Sep 4, 2012 02:04 PM
96jimmyslt4x4
Sep 21, 2011 09:14 AM
96jimmyslt4x4
May 29, 2011 03:55 PM
David Reeves
Dec 15, 2009 04:23 PM
Blaize70
Jun 20, 2005 04:22 AM
