LED Rock Lights With Keyless Entry, Second Opinion?
Old Jan 30, 2018 | 10:25 AM
95teal4x4's Avatar
95teal4x4 is on a distinguished road
Default LED Rock Lights With Keyless Entry, Second Opinion?
First off, i have a 1995 4 door blazer 4x4. it has the factory keyless entry. i also have the factory gm service manual with all the wiring diagrams in it for my blazer. i would like a second set of eyes to look over this
I dont know about newer blazers, but my headlights or parking lights have never flashed when i used my keyless entry. one of the things i hate the most about this car. this makes the keyless entry practically useless because you have to be nearly 5 feet away to hear the doors unlock.
So i just wanted to hear everyone's opinions on this before i went ahead and did this mod. No where on this site did i see any threads on this. many jeep owners have done it. i would like to installl some LED Eagle eye rock lights to come on with the dome light when i activate the keyless entry. but i do not want them to come on when i turn on my dome light. after doing some research on a few forums, i think i came up with a setup. i have ordered the rock lights but have not bought anything else yet.
Here is what i came up with:
The rock lights would be run in parallel like they are in the drawing. I believe this setup, by using a 5 pin relay, would allow me to switch the rock lights on and off using a rocker switch but when the keyless entry module sends the illuminated entry signal out, would energize the relay and the lights would come on. i would of course add a fuse to the side of the relay that has the coil so i don't burn up the relay.
the only catch with this setup, being on the ground side of the circuit, that is a lot of wiring that i would be running that is hot all the time. Do you guys think that would be an issue? if you have any ideas on how i could improve it, don't hesitate to tell me.
here is the factory wiring diagrams that i used to come up with it. the first picture, where i'm pointing to is where i would tie the relay into the circuit.
Thanks for looking!
Old Jan 30, 2018 | 03:20 PM
When I was looking for ways to create a switched aux-pwr outlet on my 99 (https://blazerforum.com/forum/lighti...outlets-96201/), I found at least one circuit that was hot at all times and only active when a switch to ground was closed. (I can't remember what it was though.) It made it impossible for me to use that circuit for my purposes but I could not think of any reason why in principle why such a circuit could not work.
What I did end up doing that you might find useful was to tap directly into the Body Relay Block to a switched signal that I did use to turn on the relay that switched the power to my aux-power outlet. (https://blazerforum.com/forum/lighti...-access-96173/)
BTW, I couldn't quite make out all of your notes on your circuit diagram. Could you repost it with greater resolution?
Old Jan 30, 2018 | 07:43 PM
95teal4x4's Avatar
Here is a larger picture of my drawing of my circuit. I bought the switch, relay and i got the rock lights. All that is left is a diode and a fuse.
Old Feb 7, 2018 | 10:01 AM
95teal4x4's Avatar
well i only have one light done so far but i was able to wire in a relay and tap the power and ground at the courtesy light and got the led light to come on when you open or close the door and with keyless entry. I do plan on putting 1 under every door eventually. My wiring is not the same as it is in those photos but i will do a detailed write-up on my build thread and if a lot of people are interested, i might even do a how-to thread. I love it. Gives the blazer a nice modern high-end look!
I just got it done the other night so i dont have any pics of it lit up but dont worry, they will posted on my build thread soon.
Old Feb 7, 2018 | 10:43 AM
Cool. Be sure to post more pics.
So on your wiring diagram what is "KEM" the power source for the coil?
Old Feb 7, 2018 | 10:47 AM
95teal4x4's Avatar
KEM was just the abbreviation for Keyless Entry Module where i was originally going to tap the ground for the relay which when that circuit closed, would trigger the relay. I decided it was easier to just use a splice connector and tap the hot wire and the ground wire for the Left floor courtesy light.
Old Feb 7, 2018 | 12:39 PM
Lefet's Avatar
Lefet is on a distinguished road
SWEET! Definitely will be following the install.
Old Feb 10, 2018 | 01:18 PM
95teal4x4's Avatar
for everyone who has replied to, subscribed to, or looks at this thread, i have posted a detailed write-up and how-to on my build thread. post #103, page 11 of my build thread. i look forward to hearing your comments!
since my signature no longer appears to be showing up on my posts, here is the link to my build thread;
https://blazerforum.com/forum/builds...ts-pics-93630/
Last edited by 95teal4x4; Feb 10, 2018 at 01:21 PM. Reason: no signature, had to post a link
michaelmiata89
Mar 17, 2013 03:32 AM
berryd8
Sep 29, 2009 06:28 PM
regulator71
13
Feb 10, 2009 05:51 PM
gscrippler
Dec 17, 2008 08:02 PM
knightrider79
Sep 6, 2006 12:35 AM
