Lights Lights Lights
Is there a way to shut off the lights with the vehicle still on? Some type of button sequence or something. I have an '03 ZR2
You might try to engage your parking brake I know my dads 2000 s10 works like that.
Its a manual tranny...and my parking brake doesnt work anyway
My dads s10 is a 5 speed, I don't think it matters if it engages the brake their would possibly be a sensor to detect when the ebrake pedal is pushed and turn the lights off.
oh alright, well i was kinda going for being parked in nuetral on a trail with the engine running but lights off
I asked a similar question, my lights only go off if the truck is off....told 2 things ... 1) push dome button twice (tried a lot of different ways with this nothing worked).... 2) disconnect the sensor (right dash speaker grill..that little nub) and wire in a 2.2k ..1/2 watt resistor...(gonna try it tomorrow)... hope this helps scott............... update: the sensor is for the auto headlights not daytime running..found another post about bending a lead of one of the fuses in the engine compartment..it worked no more daytime running lights.
in my 03 s10/.. if you press the dome light very fast you can turn off daytime runing lights.. it takes a coupla tries to get it figured out. yours should be off in neutral if you either do ebrake or or switch trick...
push the dome over ride button 4 times. It will shut off all DRL and Auto headlights. Does in my 03 Z
OK i will try tomorrow...if the button doenst work I'll just try to disconect sensor...opinions on why i shouldnt? Thanks much
Evan
I just tried pushing the dome override in various sequences and none worked.
Shoot, i forgot to try to hold ebrake in while doing. Disregard will try that.
Evan
Last edited by swartlkk; 12-20-2010 at 07:34 AM. Reason: *Combining Consecutive Posts* - Please use the EDIT feature to add additional information to your post if another member yet to respond.
The dome override trick doesn't work on trucks that were manufactured for sale in Canada.
