Lights slight pulse - video
Old Feb 16, 2017 | 12:23 AM
cdtek101's Avatar
cdtek101 is on a distinguished road
Default Lights slight pulse - video of it
I read some posts of similar issues, but mine does not fit what I found.
I noticed tonight my headlights and my dash gauge lights have a very slight pulse look, sometimes a slight dim effect.
not really a flicker ..nor do they go out.
Only at idle around 650-700 rpm once rpm increase to around 800+ it
stops.
See video - just above center line band of bright white light.
https://www.youtube.com/watch?v=iseQ...ature=youtu.be
Inline volt meter stays 13.8 to 14.1
The alternator is 6 mos or less old.
Battery is less then a year old.
Ideas on what it could be. ?
Old Feb 16, 2017 | 12:12 PM
chevyriders's Avatar
Sounds like it could be a symptom of a bad ground. I would start by checking and cleaning all your connections on your main grounds and seeing if that solves it.
Old Feb 19, 2017 | 08:36 AM
bajablazer93's Avatar
bajablazer93 is an unknown quantity at this point
Ive had an issue on my 95 with my lights pulsing, i was already looking to upgrade my alternator because of the lights i was going to be adding. Put in the ad244 and have not had any issue with pulsing lights anymore.
Old Mar 29, 2017 | 06:58 AM
jeffinohio's Avatar
jeffinohio is on a distinguished road
Had the same issue.Voltage regulator in the alt was causing it.Replace alt,good to go.
hanksta2
Jan 25, 2013 03:57 PM
Dadatone
Aug 27, 2012 07:45 PM
svd85
Nov 28, 2009 09:10 AM
TruckeeT2
Performance & Brainstorming
Jul 21, 2008 08:19 PM
br1amb
Mar 28, 2008 08:58 AM
