measurement values, sensors 4,3L 1999
Old Jan 16, 2019 | 07:31 AM
Thebard's Avatar
Thebard is on a distinguished road
Smile measurement values, sensors 4,3L 1999
I have a 1999 Blazer S10. 4,3L. What I wonder about is the measurement values of the different sensors on the car. Searching around online, but I can't find much. Does anyone have that information? Not sure if this was good English, I'm from Norway :-)
I have a diagnostic tool, but the numbers don't tell me much, as long as I don't know what's right.
Have a nice day..
Old Jan 16, 2019 | 07:49 AM
cleburne red's Avatar
Are you asking about like if you were to use a volt meter to measure them? There's a website I've used to troubleshoot a few sensors on my 95, not sure how much would apply to your 99 though. I'll see if I can find it
Edit: Here you go
There's a ton of articles there, hopefully it'll help you out
Edit 2: just realized you might have meant what was the normal readings to expect to see from a scan tool?
Old Jan 16, 2019 | 08:02 AM
Thebard's Avatar
Hi, thanks for the answer.
on my scan tool I can read live data from the sensors. temp, rpm, volts and such. But I don't know what the different sensors should show normally.
Old Jan 16, 2019 | 08:11 AM
Yeah, kinda what I figured once I started thinking about it.
Is your truck running fine? Any trouble codes?
And is there any sensor in particular you have a question about?
Old Jan 16, 2019 | 08:21 AM
LesMyer's Avatar
Very good English! I know what you are asking for, but the PCM already does this for you (and it is much more efficient and particular). It is constantly monitoring all sensors and controls to ensure they are working within designed specifications. If anything is out of spec or inoperative, it turns on the SES light and sets a code specific to the problem. Then you perform the factory diagnostic chart for that particular code to diagnose the problem. The normal working range for a sensor or monitored device is usually buried in the diagnostic chart information (especially circuit description and/or diagnostic aids). You can obtain the diagnostic charts by purchasing a factory service manual or by subscription to ALLDATADIY.com or go here (some of the links no longer work but try to open images in a new window) https://blazerforum.com/forum/tech-a...agnosis-26408/ Hope this helps.
Old Jan 16, 2019 | 08:54 AM
Thebard's Avatar
The car works pretty well. Probably not 100%, so I want to see if all sensors work as they should. There is one thing that is not quite good. sometimes the engine stalls/suffocate when i press down the accelerator pedal. most often from start. Maybe I should check the pressure on the fuel pump?
Old Jan 16, 2019 | 09:27 AM
Thebard's Avatar
Thanks :-) I have no engine light or codes at the moment. is just curious. Fuel is expensive in norway. about 7 USD for a US gallon. Want the car to be as good as possible :-)
christine_208
Apr 6, 2024 09:05 AM
Tuna
Apr 1, 2022 03:50 AM
GeorgeLG
Jun 19, 2017 10:11 PM
mike860
Mar 7, 2014 08:35 PM
Bojib
Dec 9, 2005 08:48 PM
