Mod to run fog lights as cornering lights?
Old Jul 21, 2013 | 03:09 AM
ClickBoom's Avatar
ClickBoom is on a distinguished road
Originally Posted by Thogert
Wait, how are you planning to make the fogs come on then? Just a switched +12v source tapped into the turn signal wire? If that's how you would do it then you'd want the diodes between the turn signal tap, and the switched +12v for the fog light function.
If you aren't going to use them as actual fog lights anymore, you don't actually need any diodes.
Haha okay, to be as clear as possible, I have drawn up a little diagram of how I'd wire the relay. I am still wanting them to be fog lights, so I will need the diode. I do know I have to put it in-between the signal and the source, but I wasn't sure on which side of the relay. (If it really matters)
Old Jul 21, 2013 | 07:53 AM
Thogert's Avatar
Ok this is how you would do one side, the fog switch would need to be split into two wires to run to each relay and the two diodes so each side doesn't feed the other as well.
Attached Thumbnails Mod to run fog lights as cornering lights?-relay_zps1ddccaca.png
Old Jul 21, 2013 | 09:31 AM
ClickBoom's Avatar
I didn't even think about them flowing into each other. Well thanks, I'll take a trip to RadioShack here and see about getting this done!
Old Jul 22, 2013 | 03:23 AM
Thogert's Avatar
Let us know how it turns out.
m3dragon
Feb 24, 2015 10:04 AM
SWANNERZ
Aug 13, 2014 05:05 PM
chris015
Engine & Internal
Jul 2, 2012 01:04 PM
R2P
Nov 1, 2009 08:03 PM
ewingmh
May 13, 2007 07:21 AM
