Mounting KC HiLites
Old Dec 16, 2011 | 05:01 PM
BigEffingHammer's Avatar
BigEffingHammer is on a distinguished road
Default Mounting KC HiLites
Hey guys, I was curious how/where I should mount the pair of KC HiLites that I got. I don't have a light bar (yet) so I was thinking on mounting them to the bumper. Should I just put them to the left/right of the stock headlights respectively and drill holes through the bumper and mount them there?
Just curious on your opinions.
By the way, these are the 6" 100w lights that are not the slim ones, but I'm fairly sure it'll work out on the bumper.
Old Dec 16, 2011 | 06:34 PM
warthogdriver's Avatar
what i would do as to save your bumper from the drill is get a piece of steel from the depot and drill it out and then use the mounting locations on the bumper to bolt on the steel and the lights.
that way when you do get your light bar you dont have empty holes in your bumper.
i am a fan of reversible temporary mods...
Old Dec 16, 2011 | 06:40 PM
I, too, am a fan of reversible temporary mods.
What do you mean by the mounting locations on the bumper? Like, where you mount the bumper to the frame?
Old Dec 16, 2011 | 07:01 PM
yup, i would pop out your grille and check out the two bolts that mount the top of bumper to the frame...prime temp mounting spot i would think
Old Dec 16, 2011 | 07:10 PM
You, my friend, are a genius. Now, I just need to find some flat steel.
Oh, how thick do you think it should be to support the lights?
Old Dec 16, 2011 | 07:34 PM
i would think some 1/8 inch would be more then enough as long as you dont go out like 3 feet.....j/k
its prob a couple bucks at the depot and i would think 1" wide by 1/8" thick would be fine.
the dist depends on the size of your lights and getting them away from the grille a little.
Old Dec 16, 2011 | 07:37 PM
AJBert's Avatar
You will need to bend the steel to get the clearance you will need so as to not interfere with the bumper. It's been done before but bending 90 degree angles on 1/4" steel can be a little difficult.
Old Dec 16, 2011 | 08:04 PM
A'ight, so 1/8" thick. Lights should look fine assuming they're not sticking out too far, right?
Old Dec 16, 2011 | 08:44 PM
could always request a photo chop of your ride.
ked1991
May 6, 2013 11:12 AM
dlmallory
Feb 10, 2012 12:09 PM
clutch
15
Jan 5, 2007 02:58 AM
Canadian88
Jun 25, 2006 04:33 PM
reapersimage
May 22, 2005 04:53 AM
