need help with gas gauge.
Old Nov 10, 2011 | 10:18 PM
DamienAngel's Avatar
DamienAngel is on a distinguished road
Default need help with gas gauge.
I bought my blazer abought a month ago. have some issues with it. the dreeded blinker noise. and my gas gauge doesnt work. anyone have any ideas?
Old Nov 11, 2011 | 07:29 AM
Both are common issues that are covered fairly well in the Tech Article (DIY) section. Check out the link to the index of this section in my signature below.
The blinker issue is most likely a faulty hazard switch which is part of the multifunction switch. It can be replaced independently as covered in the tech article section.
The gas gauge needs to be diagnosed. Again, the diagnostic procedure can be found in the tech article section.
Old Nov 13, 2011 | 09:52 PM
ty ill go over them again. thanks.
Old Nov 13, 2011 | 11:30 PM
gatorboy44's Avatar
gatorboy44 is on a distinguished road
My gas gauge didn't work when I purchased mine because the float on the fuel pump assembly was no good. Just a little input.
Old Nov 15, 2011 | 11:10 PM
Blade_24k's Avatar
Blade_24k is on a distinguished road
When I got my 00' Jimmy the fuel gauge didn't work. Turned out to be the sending unit on the furl pump was shot, and unfortunately it can't be changed independently. Gotta get a whole new fuel pump. But ganged mine and it wires now.
Old Nov 16, 2011 | 07:36 AM
gatorboy44's Avatar
If you decide to change the pump only use ac delco or bosch fuel pump assemblies, airtex may seem like alot of money saved but they tend to go right back out again. Is your needle above full or is it sitting at empty at all times?
Old Nov 17, 2011 | 09:37 PM
kool thanks for the info everyone . so i am gonna have to drop the tank to fix it. yay.
Old Jan 26, 2012 | 01:54 PM
patitur77's Avatar
patitur77 is on a distinguished road
I have a 97 blazer 4x4 lt 4 dr and my gauge stays past full. Any input would be great!
Old Jan 27, 2012 | 07:00 AM
gatorboy44's Avatar
If it moves barely occasionally, then your float is probably bad/stuck. You'll need a new fuel pump assembly. I just replaced mine
Old Feb 1, 2012 | 10:50 AM
patitur77's Avatar
I have heard that it could be some type of ground that goes under the body of the truck with a bad connection, make any sense of that? If so then where is it located?
