Need some help with doing big 3 upgrade.
Hello, I have a 2005 2 door blazer and I am about to do a big 3 upgrade with 1/0. I have done this before in a cobalt but it was totally different. I need to know what wires I need to replace or add to. and what grounds. I see the pos going from batt to alt but it goes into a small box behind the headlight before going to alt. I see the ground going from batt to the engine but I don't see one going from the engine to frame or body. Where is this or where is a good spot to add one. I know how the big 3 works just looking for some blazer specific help. Thanks!
Note: I am still running stock alt and batt but am getting a 270 amp alt and d3400 in a few weeks.
What people usually do when they do the big 3, is leave their existing wires, and just add the upgraded wire.
The one from the engien to body (from the alt to the body) what I Would do there, and did do) is run the ground to the negative on the battery post. then run a really good solid ground from the battery to the frame.
I hope this clears anything up.
Will be running 7-8k eventually so I want it to have strong electrical.
engine to chassis/frame, is the alt ground to the body.
so if you have the power from the battery to the alt already done, then the other wire that is there, is the ground for the alt/engine. run that to the - on the battery, or somewhere that will give you a good solid ground.
Now, on my alt when i did the big 3, instead of the ground wire being bolted to the alt, it was a plug, so what I did was bolted the larger gauge wire to the alt bracket, so it was in contact with the alt case.
Ok, do you know where a good spot on the frame would be?
chipjumper
Jul 27, 2008 10:28 PM
