New Blazer owner...HELP!!
Old Oct 28, 2013 | 01:25 PM
skynyrdmh's Avatar
skynyrdmh is on a distinguished road
Default New Blazer owner...HELP!!
I just aquired a 1995 Blazer LS. Many issues I need to get straight so I will be visiting this forum a LOT!! Lets start here. Power seat does not work. I checked for fuses but the only fuse panel I see is at drivers side end of dash. Is there another?? Also the 4x4 push button switch does not seem to work. Any way to test these switches?? And 1 more for now....how can you open the back glass if the electric motor wont unlatch it??
Old Oct 31, 2013 | 01:41 AM
Thogert's Avatar
There is an access hole just under the top middle section of carpet on the inside of the tailgate. There is a small arm in there that you need to push to the side to unlatch the window. You can see it here with the carpet removed.
It's the little goldish arm in the hole there.
Attached Thumbnails New Blazer owner...HELP!!-photobucket-2943-1327519730987.jpg
Old Oct 31, 2013 | 12:26 PM
skynyrdmh's Avatar
Thanx!! got the back glass and tailgate working!! But still have an issue with lock button not releasing glass. Works from dash button but not from rear lovk button. Any ideas?
Now the power seat. It is set in the most back position and need to get it forward. Checked all fuses and circuit breakers and all seem to be good. Next I am going to try to remove the seat to get good access to wires. Not gonna be fun as the seat is over the rear bolts!! Any input here would be greatly appreciated!!
Old Oct 31, 2013 | 01:37 PM
Thogert's Avatar
There is a plug for power under the seat. Run a temporary live wire to the positive and a ground to the negative to get it to a better position to work on.
nate.chesebro
Nov 2, 2011 02:15 PM
Menace
Apr 25, 2011 09:41 PM
jmkimes
Apr 24, 2011 10:57 PM
Mrs_Blazer
Jul 22, 2009 11:03 PM
mysons95
Oct 11, 2008 05:26 PM
