New to forum need help
Old Jan 25, 2020 | 07:35 AM
Tony123's Avatar
Tony123 is on a distinguished road
Default New to forum need help
2002 LS 4X4
When I bought the truck I noticed that when I put it in gear it would automatically lock the doors. It just stopped
I used to have running lights
can't get it into program mode for key fob
sometimes the lights don't come on on overhead compartment when key is off the push-button ones
my alarm used to work when I lock the door I still have a blinking light but no sound from the horn
I checked all fuses but not the relays
Truck has 150,000 miles
also have a clunking sound when I make a left turn or go over a bump
thanks for any help
Old Jan 25, 2020 | 12:48 PM
LesMyer's Avatar
Sounds like related to the BCM, but not to imply that it is defective and should be replaced. Needs someone technically adept to diagnose per factory information.
Old Jan 26, 2020 | 03:10 PM
Your clucking could be a bad ball joint.
Old Jan 26, 2020 | 03:11 PM
Since you are new, "BCM" = Body Control Module. It is one of the small electronic "brains" that runs our Blazers. You might have some bad connections in the wiring harness.
Kipper667
Dec 11, 2018 12:17 PM
kmgrimm1
Oct 26, 2013 05:04 PM
michaelmiata89
Mar 17, 2013 03:32 AM
el8232
Oct 22, 2010 11:52 AM
J_man01
Oct 3, 2010 01:22 PM
